syntax for matches_glob
Hi, having syntax problems with matches_glob function. I have this, which works: if { $agent matches_glob “*android 2.1*” } { do something }, what I want to do is implement an OR type operator on a string within the string $agent. similar to switch -glob using - after the string match. Is this possible? I have not been able to find any syntax reference for the matches_glob command. thanks in advance.
The best I have been able to do is something like:
if { ($agent matches_glob “*android 2.1*”) or ($agent matches_glob “*android 2.2*”) or ($agent matches_glob “*os 1.0*”) } { do something }.
but I am not sure of this is the most efficient way of doing something like this?
Any suggestions would be gratefully received.
thanks.
Hi nnzaid,
The second syntax you have would work. But you can use a switch statement instead:
   switch [string tolower [HTTP::header User-Agent]] {
      "*android 2.*" -
      "*os 1.0*" {
          Do something
      default {
          Do something else
Aaron
Thanks Aron.
Much appreciated.
