I’m testing http header manipulation. I’m trying to figure out the syntax of table 13.15 of the LTM Config Guide. I have the following functioning iRule:
set URI [HTTP::uri]
if { $URI starts_with “/foo.html” } {
log local0.warn “URI starts with foo.html”
HTTP::header replace host foo.gwrf5.com
HTTP::uri “/foobar.html”
use pool foo
Is there some reason I can’t set the HTTP::host header in the same fashion as the HTTP::uri? When I try the rule as follows:
set URI [HTTP::uri]
HTTP::host “foo.gwrf5.com”
use pool foo
I get the following syntax error when saving the rule:
01070151:3: Rule [rewrite] error:
line 5: [wrong args] [HTTP::host “foo.gwrf5.com”
Also, when I try the rule as follows:
set URI [HTTP::uri]
log local0.warn “URI starts with foo”
HTTP::header host foo.gwrf5.com
use pool foo
It saves fine, but I get the following runtime error:
May 27 01:22:08 tmm tmm[4286]: 01220001:3: TCL error: Rule rewrite - Illegal argument. Illegal argument. Illegal argument. Illegal argument. Ille (line 1) invoked from within “HTTP::header host foo.gwrf5.com”
Seems to me like both of these other rules should work according to the documentation. I didn’t want to dump this to support until I knew for sure what I was doing.
Thanks,
Wes
