Syntax error trying to block a cipher
using this command tmsh create ltm profile server-ssl rc4-ssl ciphers “DEFAULT:!RSA_RC4:!ECDHE+RC4”
I get the following error… -bash: !RSA_RC4: event not found
How should the command look>
update - I am trying to remove all the RC4 ciphers - version 11.4.1 - tmsh create ltm profile server-ssl rc4-vuln ciphers “DEFAULT:!RC4” gives me same error
Here a list of supported ciphers in 11.x
This solution doesn’t tell me why I keep getting a syntax error on my attempt to remove create a profile without the RC4 in it.
I need to get rid of the RC4 entries
single quotes instead of double quotes makes all the difference!! thanks to the help desk!!
