Syncing Devices with different builds
Hi all,
I am carrying out a rebuild of an F5 WAF VM, and it looks like the builds are slightly different between the current active member and the build Ive just downloaded from F5 downloads - 16.1.0 0.28.19 (Engineering HF) vs 16.1.0 0.0.19.
Ive built the new device on 16.1.0 0.0.19, and tried to import a UCS file from the old VM device, and its failed.
Is this likely due to the build descrepency? Or how best can I get the config imported?
I obviously need to get the devices on the same build, so is there a repository for older builds? Or is it possible to export a build from a F5 device and import that?
Thanks,
D
In case this may help someone else…
I managed to export the EHF from the current active device using WINSCP.. located in /shared/images.
You will need EHF and base image. See here - https://support.f5.com/csp/article/K55025573
Then I needed to copy the master key from device to new.
https://support.f5.com/csp/article/K82540512 - UCS Migration
https://support.f5.com/csp/article/K9420 - Master Key Export
