i have problem to sync ASM policies , between two nodes
Please if you can advice or help ?
Have you setup an ASM synchronisation group?
Yes ASM sync group is configured
what is the exact issue? is nothing synced? are parts synced?
when you perform a sync have a look at the /var/log/ltm and /var/log/asm file and look for lines talking about the sync.
Thanks i opened ticked with F5 TAC , but i am waiting F5 feedback
