sync issue
I am using two unit of ltm VE, configuring sync failover. Failover part is working fine but status of sync on one device says disconnected and on other Awaiting initial sync with changes pending
How to solve this issue
I had a trust issue with my nodes last week after an upgrade. I had to remove the peers on BOTH sides, add it on ONE side and perform the initial sync.
You might need to verify the Device Management > Device Groups > BIGIP_DEVICE_GROUP settings on both bigips. I had the same issue when one bigip had “Full Sync” checked and the other did not.
