SYNC FAILED: Caught configuration exception (0), Can't load monitor instance tcp:8184 - ltm/validation/MonitorRule.cpp, line 1606.
Hi
any idea how to overcome this situation without switching over to the standby or doing a reboot of the active device in the device-group?
Jun 19 11:43:11 XXXXX err mcpd[6051]: 01070712:3: Caught configuration exception (0), Can't load monitor instance   for /Common/XXXX-tcp:8184 - ltm/validation/MonitorRule.cpp, line 1606.
Your feedback is much appreciated
Sven
Known Bug on 11.3.0 HF6
for pool in `tmsh list /ltm pool one-line | grep  'Customized-tcp' | awk '{print $3}' `; do echo "tmsh modify ltm pool $pool members modify { all { monitor default } }" ; done`
And run
tmsh save sys config
afterwards.
