I reconfigured an iApp to remove SSL from the VIP. Now when I sync config I get this error. Any suggestions one what is failing to validate?
CM::Sync Status
Color red
Status Sync Failed
Summary A validation error occurred while syncing to a remote device
Details
/Common/f502.kfi.kdc.int: connected (for 86527 seconds)
/Common/device-group-1 (Sync Failed): A validation error occurred while syncing to a remote device
- Sync error on /Common/f502.domain.int: Load failed from /Common/f501.domain.int 01070283:3: The profile (/Common/app.domain.int.app/app.domain.int_client-ssl) is currently associated with one or more virtual servers.
- Recommended action: Review the error message and determine corrective action on the device
I think can answer my own question here. This iApp was the f5.http and when I removed SSL it must have left some objects behind (perhaps the SSL profile, though I didn’t see this in the webGUI).
I deleted the ‘iApp\service’ and recreated it from scratch. Then I was able to successfully sync config with the peer.
