Symphoniq TrueSpeed
A new tool has been created to measure the performance improvement of using F5 Acceleration products. The tool is TrueSpeed from Symphoniq, an F5 Partner.
You can register to download a free trial at:
http://www.symphoniq.com/go?341
Measure the impact of F5’s BIG-IP with TrueSpeed
- Automatically and accurately document the performance improvements delivered by BIG-IP
- Immediately see the results of BIG-IP features like compression, caching, and WebAccelerator
- Accurately determine which configurations and parameter settings will deliver optimal performance
- TrueSpeed is a lightweight Windows application that can run on practically any machine, including laptops.
How is this accomplished from the bigip perspective? Do you know how symphoniq is grabbing the data?
TreeSpeed does work well for BIG-IP LTM data. It has a combination of capabilities for collecting data. Some of the advanced capabilities ustilize F5’s open API, iControl. The TrueSpeed and TruView products are a powerful part of the F5 ecosystem.
Joe
It looks like you have to install the software though to measure the end-user experience.
I have been looking for a way to measure the end-user experience from all the user’s points of view.
I have only been able to find ways to send synthetic transactions and then see the results or get stats from the server and load balancer and do my own analysis. Or in this case, install Symphoniq on a laptop and check from my point of view. Is this accurate?
