trx
June 15, 2011, 11:21pm
1
Hello All,
For some reason my switch is NOT working correctly.
ex)
when HTTP_RESPONSE {
if request is a static file, set cache control to be cached on the client machine for 7 days
if { [HTTP::header exists Content-Type] } {
switch -glob [HTTP::header Content-Type] {
“text/javascript” -
“text/css”-
“image/gif” -
“image/jpeg” } {
HTTP::header replace “Cache-Control” “private, max-age=604800”
Any thoughts why this is happening?
Regards,
TRX
There should not be “}” after “image/jpeg”.
"text/javascript" -
"text/css"-
"image/gif" -
"image/jpeg" {
HTTP::header replace "Cache-Control" "private, max-age=604800"
Keep in mind that these comparisons are case sensitive. It might make sense to include a string tolower along with the switch comparison statement, depending on what piece of data you’re switching on and whether or not it can be multi case.
Colin
hoolio
June 17, 2011, 5:07pm
5
Yes, the iRule should work the same in terms of rewriting the headers for HTTPS. Can you check the actual HTTP headers in the responses to see if the cache control header is being set as you expect?
Aaron
trx
June 17, 2011, 5:11pm
6
It ONLY shows in the HTTP images and NOT HTTPS images.
Here is the code in the SSL VS:
“text/javascript” -
“text/css” -
“image/gif” -
“image/png” -
“image/jpg” -
“image/jpeg” {
Thoughts?
Regards,
TRX
hoolio
June 17, 2011, 5:13pm
7
Can you try this:
curl -kv https://1.1.1.1/static\_content.file
where 1.1.1.1 is the virtual server IP and /static_content.file is the name of a static file?
Aaron
trx
June 17, 2011, 5:23pm
8
Do you want me to try this in the browser?
Browser info:
https://insidedev.qad.com/vgn-ext-templating/common/styles/vgn-ext-templating.css
HTTP/1.1 200 OK
Date: Fri, 17 Jun 2011 17:24:40 GMT
Server: Microsoft-IIS/6.0
Etag:
X-Powered-By: ASP.NET
Content-Type: text/css
Last-Modified: Mon, 03 Nov 2008 22:17:26 GMT
Content-Language: en-US
Server: WebSphere Application Server/6.1
Connection: Keep-Alive
Regards,
TRX
hoolio
June 17, 2011, 5:29pm
9
Sorry, no from the LTM command line.
Aaron
trx
June 17, 2011, 6:44pm
10
I’ve never used SSH to connect the LTM yet. I"ll have to learn that. Are there any quick tutorials on that?
Also, this is weird that the IRules for HTTPS set cache control response headers on our PRODUCTION site but just NOT our DEVELOPMENT site.
Any reason why would that be? It’s go the same IRules and very similar VS/POOL/Members setup.
Thoughts?
Regards,
TRX
hoolio
June 17, 2011, 6:50pm
11
You can use Putty to connect to the LTM command line:
Download PuTTY: latest release (0.85) → http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe
Can you try testing from the command line using curl and compare what you see in production with development?
Aaron
trx
June 17, 2011, 6:58pm
12
Thanks. I’ll try that and let you know my results.
