I’m trying to do something very simple - just get a list of pools.
The trouble is that I don’t get any results. The sample LocalLBPool.pl doesn’t return results, and neither do any of my own efforts.
Can anybody give me a clue as to what basic step I might be missing?
I’m wondering if my problem is that I do not have permissions sufficient to run these calls.
When I go to the web interface, I can see the pools. I can view information about the members of the pools. I cannot change the status of the pools, nor create or remove members of the pools.
I can run a few API calls and get results. Everything having to do with pools seems to return no data or errors.
I am writing an application monitor that will disable a pool member should the application go down, and conversely enable a pool member should the application come back up.
If I were to go to the F5 administrator today and verify permissions, is there a way to describe the permissions that I need clearly? I’ve been banging my head against a wall for a very long time and I would like to be able to describe my needs clearly.
If you have a read-only account, then you should be able to get results from the get_list() methods. If you turn on SOAP tracing, you can get the raw request/response output which can sometimes find the root cause of issues.
use SOAP::Lite + trace => qw(method debug);
As for permissions to be able to toggle states, you will need to either be an Operator or Administrator.
-Joe
I did grab the raw xml and here is what I received:
xmlns:E="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:A="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:s="http://www.w3.org/2001/XMLSchema-instance"
xmlns:y="http://www.w3.org/2001/XMLSchema"
xmlns:iControl="urn:iControl"
E:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> xmlns:m="urn:iControl:LocalLB/Pool"> s:type="A:Array"
A:arrayType="y:string[0]">
If I open my browser and go to: https://myf5server/tmui/Control/jspmap/tmui/locallb/pool/list.jsp?Filter=*
I do see a list of 8 pools.
When I turn on the trace info as you stated above, I receive the following:
SOAP::Transport::new: ()
SOAP::Serializer::new: ()
SOAP::Deserializer::new: ()
SOAP:arser::new: ()
SOAP::Lite::new: ()
SOAP::Transport::HTTP::Client::new: ()
SOAP:arser::new: ()
SOAP::Lite::new: ()
SOAP::Lite::call: ()
SOAP::Serializer::envelope: ()
SOAP::Serializer::envelope: get_list
SOAP::Data::new: ()
SOAP::Data::new: ()
SOAP::Data::new: ()
SOAP::Data::new: ()
SOAP::Transport::HTTP::Client::send_receive: HTTP::Request=HASH(0x86fe744)
SOAP::Transport::HTTP::Client::send_receive: POST https://myf5server:443/iControl/iControlPortal.cgi HTTP/1.1
Accept: text/xml
Accept: multipart/*
Accept: application/soap
Authorization: Basic **REMOVED**
Content-Length: 428
Content-Type: text/xml; charset=utf-8
SOAPAction: "urn:iControl:LocalLB/Poolget_list" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
SOAP::Transport::HTTP::Client::send_receive: HTTP::Response=HASH(0x8a18a10)
SOAP::Transport::HTTP::Client::send_receive: HTTP/1.1 200 OK
Connection: close
Date: Mon, 17 Dec 2007 19:13:59 GMT
Server: Apache
Content-Type: text/xml; charset="UTF-8"
Client-Date: Sun, 16 Dec 2007 14:00:53 GMT
Client-Peer: 171.64.11.167:443
Client-Response-Num: 1
Client-SSL-Cert-Issuer: /C=--/ST=WA/L=Seattle/O=MyCompany/OU=1177687786/CN=bigip/emailAddress=root@bigip
Client-SSL-Cert-Subject: /C=--/ST=WA/L=Seattle/O=MyCompany/OU=1177687786/CN=bigip/emailAddress=root@bigip
Client-SSL-Cipher: DHE-RSA-AES256-SHA
Client-SSL-Warning: Peer certificate not verified
Client-Transfer-Encoding: chunked
Set-Cookie: BIGIPAuthCookie=**REMOVED**; path=/; Secure;
SOAPServer: EasySoap++/0.6 xmlns:E="http://schemas.xmlsoap.org/soap/envelope/"
$VAR1 = ' xmlns:E="http://schemas.xmlsoap.org/soap/envelope/"
SOAP::Data::DESTROY: ()
SOAP:arser::DESTROY: ()
SOAP::Transport::DESTROY: ()
SOAP::Transport::HTTP::Client::DESTROY: ()
SOAP::Serializer::DESTROY: ()
SOAP::Deserializer::DESTROY: ()
SOAP::Lite::DESTROY: ()
I sent a message asking about permissions to our network people. The response I received is as follows:
The … account does have “operator” permissions to the … partition. This should allow you to view the pools and pool members as well as bring the members up and down.
USER myusername
| ROLE operator PARTITION …
You mentioned the word “partition”. If your BIG-IP is configued using admin partitions and your objects are located in another partition than “Common”, you will need to add a call in your code to Management :: Partition :: set_active_partition() for your user given user name. The client will default to the “Common” partition unless you explicitly specify that you want access to another partition.
Click here
-Joe
How do I set the active partition in Perl through the SOAP::Lite module interface?
Thanks,
