Having a probem matching a dash/hyphen in a glob string match inside a switch
I tried the classic TCL way to do it which seemed to be to have the hyphen be leading or trailing so it is not seen as a range character, but that is not working in 11.x. Also tried escaping the a trailing dash which also did not work. Looking back at the TCL docs maybe the leading/trailing dash only applies to regex and not glob string?
Originally tried this which did not work
switch -glob [string tolower [getfield [HTTP::host] ":" 1]] {
"[pid][re2][do-]*tools-config.acme.com" {
log local0. "[IP::client_addr]~[HTTP::host]:[TCP::local_port clientside]~[HTTP::uri]"
Then i tried this which also did not work
Then I ended up working around the problem with this. So my prefix filter is not as good as intended in this workaround.
"[pid][re2]*tools-config.acme.com" {
So glob string matching on literal dash/hyphen is still needed. Any ideas?
Thanks Matt
