Strict-Transport-Security (HSTS) header throws Operation not supported errors
This is my iRule to add “Strict-Transport-Security” header to my http response code.
when HTTP_RESPONSE {
     set strictTransportSecurityHeader {Strict-Transport-Security}
     if { [HTTP::header exists $strictTransportSecurityHeader] } {
          HTTP::header remove $strictTransportSecurityHeader
    HTTP::header insert $strictTransportSecurityHeader {max-age=31536000; includeSubDomains}
This works fine and I get this “Strict-Transport-Security: max-age=31536000; includeSubDomains” as output.
But it throws warnings in monitoring tool
01220001:3: TCL error: /Common/StrictTransportSecurity_HSTS - Operation not supported (line 7) invoked from within “HTTP::header insert $strictTransportSecurityHeader {max-age=31536000; includeSubDomains}” Errors. Any idea what might be going wrong?
Do you see this error occurring upon every response, or just on rare occasions? Besides this rule, are there other iRules or LTM policies used?
replace :
by :
set strictTransportSecurityHeader "Strict-Transport-Security"
the use of {} define a list and not a string.
This is intermittent and there are other iRules too but none of them inserts HSTS and no LTM policies.
Since you mentioned you have other iRules.
HTTP::header insert ...
If this command is executed after issuing the HTTP::redirect or HTTP::respond command, the F5 will become confused, generate an “Operation Not Supported” TCL error and reset the connection.
Do you issue redirects or responses from the other iRules?
Yeah, I other iRules I have http to https redirects and some http::respond too… Now how do I overcome the error I need those iRules too???
After each redirect or response statement in the other iRules, use ‘event disable HTTP_RESPONSE’ function. If you structure the iRule well, you can get away by specifying it just once. You can also merge your iRules so the use of this function can be avoided. This kind of change can take your app down, make sure you test in QA. Also check out Stanislas answer, he’s right that you will not need to use HSTS iRule on HTTP VS. If possible, create a dedicated HTTPS VS (if you don’t have yet), and use the HSTS iRule there.
The HSTS irule must be applied to HTTPS VS and not HTTP.
to be sure this irule is executed before other, you can add priority to this irule event and disable event if Policy action is redirect.
when HTTP_RESPONSE priority 1 {
if {[POLICY::targets http-reply] } {
    log local0. "LTM Policy action contains redirect. Disabling event"
    event disable
    return
HTTP::header insert $strictTransportSecurityHeader "max-age=31536000; includeSubDomains"
