Has anyone seen errors like the following in the restnoded.log file?
Fri, 13 Oct 2023 12:45:34 GMT - severe: [telemetry.f5telemetry_default::My_System::SystemPoller_1] Error: EndpointLoader.loadEndpoint: provisioning: Error: Bad status code: 500 Server Error for http://localhost:8100/mgmt/tm/sys/provision
Fri, 13 Oct 2023 12:45:34 GMT - severe: [telemetry.f5telemetry_default::My_System::SystemPoller_1] Error: EndpointLoader.loadEndpoint: bashDisabled: Error: Bad status code: 500 Server Error for http://localhost:8100/mgmt/tm/sys/db/systemauth.disablebash
Fri, 13 Oct 2023 12:45:34 GMT - severe: [telemetry.f5telemetry_default::My_System::SystemPoller_1] Error: SystemStats._loadData: provisioning (undefined): Error: Bad status code: 500 Server Error for http://localhost:8100/mgmt/tm/sys/provision
Fri, 13 Oct 2023 12:45:34 GMT - severe: [telemetry.f5telemetry_default::My_System::SystemPoller_1] Error: SystemStats._loadData: bashDisabled (undefined): Error: Bad status code: 500 Server Error for http://localhost:8100/mgmt/tm/sys/db/systemauth.disablebash
Fri, 13 Oct 2023 12:45:34 GMT - severe: [telemetry.f5telemetry_default::My_System::SystemPoller_1] Error: SystemStats._processProperty: provisioning (provisioning::items): Error: Bad status code: 500 Server Error for http://localhost:8100/mgmt/tm/sys/provision
Fri, 13 Oct 2023 12:45:34 GMT - severe: [telemetry.f5telemetry_default::My_System::SystemPoller_1] Error: SystemStats._processProperty: bashDisabled (bashDisabled::value): Error: Bad status code: 500 Server Error for http://localhost:8100/mgmt/tm/sys/db/systemauth.disablebash
Fri, 13 Oct 2023 12:45:34 GMT - severe: [telemetry.f5telemetry_default::My_System::SystemPoller_1] Bad status code: 500 Server Error for http://localhost:8100/mgmt/tm/sys/provision
I pushed a json file similar to the following (Few fields redacted with variables)
“class”: “Telemetry”,
“schemaVersion”: “1.33.0”,
“My_System”: {
“class”: “Telemetry_System”,
“systemPoller”: {
“interval”: 60,
“enable”: true
“enable”: true,
“host”: “localhost”,
“port”: 8100,
“protocol”: “http”,
“allowSelfSignedCert”: false
“My_Listener”: {
“class”: “Telemetry_Listener”,
“port”: 6514,
“enable”: true
“My_Consumer”: {
“class”: “Telemetry_Consumer”,
“type”: “Kafka”,
“topic”: “myTopic”,
“host”: “myHost”,
“protocol”: “binaryTcpTls”,
“port”: 9093,
“allowSelfSignedCert”: false,
“enable”: true
What would be causing this? I tried turning it to debug and trace but didn’t have much luck. Debug didn’t show much more and I could not actually locate the trace file.
Thanks in advance,
Josh
