stream find/replace expression with an exclude
hey guys i’m stumped with a find/replace situation. let’s say i have these three strings:
“this is a string”
“i am a string”
“this is not a string”
now.. i want to replace “a string” with “a banana” however i do not want to replace “this is not a string”
what i’m doing now is this:
STREAM::expression {@a string@a banana@}
STREAM::enable
however this replaces the string i don’t want. is there any way to exclude something from the expression?
Hi Nik,
You can check what the matched string was using STREAM::match in the STREAM_MATCHED event. However, if you set your STREAM::expression match to “a string” STREAM::match is only going to return ‘a string’ and you won’t know the context of it. You could use a regex to match more of the string. Can you provide a more exact sample of what you do/don’t want to match in the content?
Here’s an example of customizing the replacement in STREAM_MATCHED:
From http://devcentral.f5.com/wiki/default.aspx/iRules/stream__expression
    Disable the stream filter for all requests
   STREAM::disable
when HTTP_RESPONSE {
    Check if response type is text
   if {[HTTP::header value Content-Type] contains "text"}{
       Match an http://*example.com string and replace it with nothing yet
      STREAM::expression {&http://.*?example\.com&&}
       Enable the stream filter for this response only
      STREAM::enable
when STREAM_MATCHED {
    Check if the matched string meets some condition
   if {[STREAM::match] starts_with "host1"}{
       Replace http:// with https:// and do the replacement
      STREAM::replace "[string map {http:// https://} [STREAM::match]]"
      log local0. "[IP::client_addr]:[TCP::local_port]: matched: [STREAM::match], replaced with: [string map {http:// https://} [STREAM::match]]"
Aaron
the problem is i’m breaking internet explorer compatibility with a find/replace that i’m doing. here’s a more specific example. again, three different strings:
http://www.domain.com/path/to/file.jpgwidth=
http://www.domain.com/file/without/quotes.html
now, if i do something like this, it replaces all three domain names with “/” however i only want to replace the second two, not the first since it breaks compatibility with internet explorer:
STREAM::expression {@http://forexforums.dailyfx.com/@/@}
using stream_matched might do the job, i was hoping there’d be something a little simpler though.
thanks.
Your post got munged. Can you edit it/reply again with the strings in [ code ] [ code ] blocks?
Thanks, Aaron
thanks.
The examples were still stripped from your post. Can you add them as an attachment?
Aaron
attached
testing…
the problem is i'm breaking internet explorer compatibility with a find/replace that i'm doing.  here's a more specific example.  again, three different strings:
now, if i do something like this, it replaces all three domain names with "/" however i only want to replace the second two, not the first since it breaks compatibility with internet explorer:
using stream_matched might do the job, i was hoping there'd be something a little simpler though.
thanks.
Aaron
I think this might work, if you only want to rewrite a href’s:
   STREAM::disable
       Match a tags for http://www.domain.com/
