STREAM Expression with exceptions
Hi all,
In my HTTP page (including form), i want to replace a string domain.com to domainservice.com But i don’t want to change if string is @domain.com.
I tried with multiple expressions with no luck
Can some one help me on this
are you using the stream profile or stream profile + iRule to apply your stream patterns?
Hi Narendra,
in case you are using iRules the following will hopefully work for you as well:
when HTTP_RESPONSE {
    STREAM::expression "\[^@\]comain\.comdomainservice\.com"
    STREAM::enable
Thanks, Stephan
You might be able to use a “null” stream match along with STREAM_MATCHED event.
Look at: DevCentral - An F5 Technical Community
I don’t know exactly how stream works, that is does it “rescan” a string after it has found and done a a replace. Could you specify a second like:
"domain\.comdomainservice\.com \@domainservice\.com\@domain.com"
Not sure if you have to escape and @ sign.
Try this:
    Disable the stream filter for all requests
   STREAM::disable
    LTM does not uncompress response content, so if the server has compression enabled
    and it cannot be disabled on the server, we can prevent the server from
    sending a compressed response by removing the compression offerings from the client
   HTTP::header remove "Accept-Encoding"
    STREAM::expression "@domain\.com domain\.comdomainservice.com"
    STREAM::enable
when STREAM_MATCHED {
    set matched_string [string tolower [STREAM::match]]
    if {$matched_string starts_with "@domain.com"} {
        STREAM::replace
        return
Hi again,
the following approach seems to work.
It seems to follow a longest match approach.
So the order of pattern mappings does not matter.
    STREAM::disable
    STREAM::expression {@domain\.com@domain.com domain\.comdomainservice.com}
    STREAM::enable
Tested on v11.5.1HF8.
Thanks, Stephan
