STREAM::expression and regular expression
Can anyone confirm that the documentation in Wiki for the STREAM::expression is correct.
I’am searching throught the stream looking for e.g. :9097/ and replace it with / . I need to use a regular expression. (since I am going to use other ports also ;-))
I have tried with the following:
STREAM::expression “@:\d{1,6}\/@/@”
Based on the documentation in Wiki this should be correct, but i don’t get any matches.
I have aslo tried
when HTTP_RESPONSE {
STREAM::enable
STREAM::expression “@\d{1,6}\/@/@”
when STREAM_MATCHED {
log local0. “***Stream match: [STREAM::match] ****”
and the output of this is
Oct 11 16:26:40 tmm tmm[1452]: Rule WAS51_Proxy : ***Stream match: d/ ***
Something tells me that this reqular expression thing is not working correctly. Any ideas?
Running 9.4.1
Ups. Wrong forum. But I found the the answer in a post from hoolio (thanks :-))
There is an error in iRule Wiki. You need to use {} instead of “” :wink:
