Greetings -
Recently we had some strange behavior and I’d like to get some opinions on the cause…
We have 3 iRules applied to a virtual server and one supporting class:
rule strip_xforwardedfor {
while { [HTTP::header exists X-Forwarded-For] } {
HTTP::header remove X-Forwarded-For
rule add_xforwardedfor {
HTTP::header insert X-Forwarded-For [IP::client_addr]
rule redirect_by_host_and_uri {
foreach row [lsort -decreasing -index 1 $::host_uri_redirector_class] {
if { [string tolower [HTTP::host]] equals [getfield $row " " 1] }{
if { [string tolower [HTTP::uri]] starts_with [getfield $row " " 2] }{
HTTP::redirect [getfield $row " " 3]
break
class host_uri_redirector_class {
"www.example.com /foobar http://foobar.example.com"
There are a whole host of reasons we use these rules, but we do use X-Forwarded-For to restrict access to some services, so it’s necessary to remove existing and re-add them. We also have a lot of fingers in the LTM with varying degrees of experience, so it made sense for use to have people edit a class rather than develop iRules.
We have a standard http vserver with something special:
virtual test_vserver {
snat automap
destination 111.111.111.111:http
ip protocol tcp
rules
strip_xforwardedfor
add_xforwardedfor
profiles
http
tcp
I originally had the rules in the order:
strip_xforwardedfor
add_xforwardedfor
because it made sense to me that we wouldn’t want to bother processing X-Forwarded-For if we were just going to redirect somewhere… This resulted in a connection reset from Windows (XP) only -- on many different workstations both internal and external with both Firefox and IE. It also resulted in these errors in /var/log/ltm
Apr 15 13:56:23 tmm tmm[1895]: 01220001:3: TCL error: strip_xforwardedfor - Operation not supported (line 2) invoked from within "HTTP::header remove X-Forwarded-For"
Apr 15 13:56:24 tmm tmm[1895]: 01220001:3: TCL error: strip_xforwardedfor - Operation not supported (line 2) invoked from within "HTTP::header remove X-Forwarded-For"
Apr 15 13:56:25 tmm tmm[1895]: 01220001:3: TCL error: strip_xforwardedfor - Operation not supported (line 2) invoked from within "HTTP::header remove X-Forwarded-For"
Apr 15 13:56:26 tmm tmm[1895]: 01220001:3: TCL error: strip_xforwardedfor - Operation not supported (line 2) invoked from within "HTTP::header remove X-Forwarded-For"
Apr 15 13:56:27 tmm tmm[1895]: 01220001:3: TCL error: strip_xforwardedfor - Operation not supported (line 2) invoked from within "HTTP::header remove X-Forwarded-For"
However, with the redirect rule moved to the bottom… all is well. No errors, no connection resets. This always worked in both OSX and Linux.
I also tried changing the xforwardedfor rules to be clientside only and received the same errors.
Thoughts?
