STP issue with Nexus 5548
We have above network and here is the cisco trunk configuration.
Nexus 5548
interface Ethernet1/9
  description F5-10G-Link
  switchport mode trunk
  switchport trunk allowed vlan 201
Cisco 3850 (non-root switch)
interface Port-channel20
 description F5-2G-Etherchannel trunk
end
interface GigabitEthernet1/0/45
 description F5-1G-a
 channel-protocol lacp
 channel-group 20 mode active
end
interface GigabitEthernet1/0/46
 description F5-1G-b
end
links are up but if i check in STP configuration on cisco my 10G link is in
blocking
mode and 2G link is
forwarding
mode, as per STP cost calculation 10G link should be in forwarding because it has total cost to reach root is
4
and 2G link total cost to root is
5
right?
Even i tried to increase spanning-tree cost of 2G link but it didn’t work still that link is in
FWD
mode.
SW2sh spanning-tree int po20
Vlan                Role Sts Cost      Prio.Nbr Type
VLAN0201            Desg FWD 3         128.2046 P2p
Nexussh spanning-tree int e1/9
VLAN0201         Altn BLK 2         128.137  P2p
If i am trying to shutdown 2G trunk then on Nexus switch i am seeing following spanning-tree status which is weird
Nexus sh spanning-tree int e1/9
VLAN0201         Desg BKN*2         128.137  P2p *LOOP_Inc
and this interface never come into
forwarding
state.
what i am doing wrong here? is my cisco config is wrong on trunk?
One more thing, This is new F5 and they are using default STP setting which is “Passthrough” But in our Cisco network we are using RSTP (PV-STP) spanning-tree. Do you think i need to change any setting at F5 side? or should i use default?
Assuming that you haven’t configured the priority on the root switch for VLAN 201, you can try this (in config mode):
  • non-root switch: spanning-tree vlan 201 priority 40960
  • Nexus switch: spanning-tree vlan 201 priority 36864
I have priority set on c3850 switch that’s is why it’s root bridge and second c3850 is sencandary root bridge.
This is not an issue about root bridge, it’s about STP failover.. even I sent very high cost on 2G link my STP doesn’t getting switch to 10G.. you can see in output.
Should I run F5 is passthrough mode? We are using PVSTP+ ?
F5 has very poor documents related it.
No one has answer ???
??? no answer
Since F5 is configured in passthrough mode, practically it is transparent for the STP (it is like your etherchannel is directly connected to the 10G link… odd…)
Change to RSTP mode in the F5.
Unfortunately i have tried (RSTP, MSTP, STP etc) everything and no luck, Problem is Cisco switches running on Rapid-PVSTP+ and F5 doesn’t understand this protocol.
In transparent mode 2G link turn into ACTIVE instead of 10G but when i try to shutdown 2G link 10G goes into loop-guard and switch never bring that port up.
In Lab i configure MSTP on cisco switch and MSTP on F5 in that case everything was working great.
Bottom line is F5 never work with PVSTP spanning-tree, if anyone did or hack something please let me know i really want that solution.
