Store JSON Web Token (JWT) as a Cookie
Scenario: I’m using F5 as an Authorization sever and back-end server/applications to handle the resource server capabilities. Now I would like to send the JWT as a cookie if any application requests from F5 APM. Please see the iRule and VPE setup below.
Problem: iRule event (jwt-cookie is being used as agent_id) is taking place before the JWT is getting issued, so I’m seeing null for $jwt-token in the LTM logs. Could you please help on how to set cookie before "Allow’ takes place?
I couldn’t attach the VPE config image with the devcentral recent changes. Flow is like below.
Start -- logon page -- ldap auth -- OAuth Authorization -- iRule event -- Allow
when ACCESS_POLICY_AGENT_EVENT {
	if { [ACCESS::policy agent_id] eq "jwt-cookie" } {
		log local0. "JWT-Cookie: Started"
		set client_id [ACCESS::session data get session.oauth.authz.client_id]
		log local0. "JWT-Cookie: Client id is - $client_id"
		set jwt_token [ACCESS::session data get session.oauth.authz.jwt_token]
		log local0. "JWT-Cookie: jwt token is - $jwt_token"
		HTTP::cookie insert "f5_jwt_cookie" $jwt_token
