Dear F5 experts
I want to reactive license on two devices in HA mode? What steps show I do and is there any considertations should I attention?
Whether reactivation will affect the HA status? Whether reactivation will affect the business? Which system services may reload when reactivation?
two of them reload config. therefore, in any case, start activating standby device, if no errors than do it on active device. myF5
I would er on the side of caution and only re-license the unit once it is in standby mode. Take note of the following warning that is in the link Faruk posted:
Important: Traffic processing is briefly interrupted while the BIG-IP system reloads the configuration. When licensing redundant BIG-IP systems, F5 recommends that you activate the license on your BIG-IP devices while they are in standby mode
When you reactivate license you have to keep in mind that the license reactivation process may reload the configuration and temporarily interrupt traffic processing. So if you want to not disturb your production follow this procedure:
You have to begin on standby member.
- Connect to standby member (Applicance-B) then reactivate license.
- once license is reactivated on standby member, check that your device is UP, ASM is started and APM session is duplicate (check on overview)
- then force active member (Applicance-a) to standby.
- reactive license on Applicance-A (standby)
- then if you want you can force standby Applicance B.
regards
