step to monitor f5
Hi All,
there is a step to monitoring our f5 machine from log ?
i found this log at /var/log/message
notice syslog-ng[5054]: Configuration reload request received, reloading configuration;
it’s seem f5 reload the config, but i cannot find who do this…
need a suggestion from dev member to check it
BR
Hey Jellf,
‘history’ command should say about the last 500 lines implemented
‘last’ command will show who logged in
Cheers,
Roger
Hi Roger,
I just found this message from /var/log/message, i think thereis a jobs do this continously every day at the same time 04.02 AM.
how we can figure it ? how we can find which script or application to this at f5.
need your help
Hi. This log entry is caused by cron (/etc/crontab), which executes /etc/cron.daily/logrotate at ~04:02 by default. The logrotate configuration files specify that logrotate should restart after files are rotated. So what you are seeing is a message from logrotate restarting after the log-rolling process has completed.
