STATISTIC_SERVER_SIDE_MAXIMUM_CONNECTIONS
using perl, how would I get_statictics for only one statistic type [STATISTIC_SERVER_SIDE_MAXIMUM_CONNECTIONS]
You are going to have to query the statistics for whatever object you are concerned with. Then within the statistics strcuture returned, there will be a list of statistic values. Lop through this until you find the type of “STATISTIC_SERVER_SIDE_MAXIMUM_CONNECTIONS”.
This statistics is available in the following objects:
NAT, NodeAddress, Pool, PoolMember, SNATPool, SNATPoolMember, and SNATTranslationAddress.
-Joe
That’s the method I used based on the sample perl code. It works great, I was just fishing for a cleaner, more direct method of getting to a perticular stat. iControl is my first experience with soap, the data structures and method and…
thanks for the help
