I am totally lost . i have used iControl to get statistics from my device.I know all the parameters. But I am confused about their description. can somone help me with a doc telling me what exactly each parameter means . I would require it for GTM and LTM for both physical and logical objjects.
Nitish. This post will probably get a better response if you post it in the specific iControl forum. Sorry I can’t help myself, iControl is not my ‘thing’.
Admittedly the iCOntrol forum would solicit you more responses, but have you looked in the iControl SDK? I’m pretty sure most (If not all) of the parameters are described… Which ones are you having problems with?
Thanks for the quick response. I am trying to derive some additional stats from what F% gives for our use. But if only i could know what EXACTLY each thing means. For eg , explicit ip .. i have no idea what it means. Can u pls help me with this problem ? can i use direct me atleast where exactly to get it ? or provide me a doc somehow
