I upgraded both of my bigip LTM to version 10.2 and now they both want to be the active unit.
I have one set with a preference of standby and the other active.
When I force the standby unit to standby it will change temporarily but then it will change to active.
I can synchronize the units using the network failover cable so they are talking to each other. The standby unit acts like it is not seeing the active unit so it changed to an active state.
I actually avoid using state preference setting as it will result in an extra failover if the preferred active unit fails and then comes back up.
Do the units have connectivity to the same management network? Have you configured the peer management address for each unit under System >> High Availability >> Network Failover?
sol9947: Change in Behavior: The Peer Management Address setting is required for BIG-IP version 10.x systems configured for network failover
Also, are the units physically close enough (50 feet) to use hardwire failover? If so, this is a faster failover mechanism than network failover.
sol1901: Obtaining a longer serial failover cable for BIG-IP, BIG-IP LTM, GTM, ASM, WebAccelerator, Link Controller, or 3-DNS
