I currently have a Active Standby pair of F5 LTMs. They each connect to a separate 6509 Cisco switch. Each Cisco switches connect to each other using Etherchannel trunk bundle. However I noticed that when upgrading a HOT FIX and rebooting my standby F5 impacted my production network as both F5s became active.
[f5 a] [f5 b]
[6509 a]---[6509 b]
I am told by F5 that it is better to directly connect the F5s together and have a separate IP subnet for the keepalives to avoid this.
Any recomendations for high availability and to prevent ACTIVE Active from occuring in an Active Standby configuration?
prior to upgrading a hot fix on my standby unit I did verify the following:
( b ha table )
HIGH AVAILABILITY TABLE
Feature Key Action En? Act Data
network failover nw_heartbeat go active yes no 35963321
network failover peer_unit no action yes no 0
( b mirror show )
No interface mirrors were found
( b db show )
Failover.ForceActive = disable Failover.ForceStandby = disable
