Stable point of Configuration " Rescue Point "
Hello Everyone,
Sometimes we need to save our configuration after big modifications to a stable point.
I know that we can take a user configuraton set “UCS” to save our Configuration with the new modification , But what about defining a new object or a stable point which I can save the new configuartion to it after making sure that all services and the Device work well without issues.
I suggest this because in busy networks such as ISPs , The governments or Banks ..etc which have several numbers of F5 appliances with multiple administarors to configure these appliances and maintain a huge number of Critical services.
So I suggest to define a " Rescue point " and save the new configuration to after validation that all services work well after new changes in configuration files or any change to F5 appliance at all , this will enable us to rollback any new changes that impacted running services or F5 resources … etc.
To show my suggestion more :
- when we need to create UCS file We issue ( tmsh save sys ucs UCS_NAME.ucs ) so similarly we can issue new command to define a " Rescue point " Like this (tmsh save sys Rescue ) and issue such this command
( tmsh load sys Rescue ) to rollback again to Rescue point which is a validated stable point for F5 system at all.
Briefly :
Defining a stable point we can call it the " Rescue point " which contains a Good status for configuration and running services , and Returning back to it again if anyone made a change that impacted the running services.
Also If a Compare option added to F5 to see the difference between " Rescue Configurations " and " New added Configuration " to see exactly what added to F5 Configuration made this impact.
Also this will help to restore impacted services quickly without the need of Loading UCS files.
This suggestion not a replacement for UCS files , it’s only a light way can help for quick services Restoration , facilitating troublshooting or to be another option for Administrators to Backup their valid changes.
I would like to see experts thoughts about this suggestion
Awesome explaination so I want to add some words when any environment having a lot of F5 appliances they must use BIG-IQ as management center to manage all the configuration and all boxes
