SSO - RDP hosts
Hello ,
i am on F5 - 13.1.4 and am trying to setup sso for remote desktop - i have enabled sso when setting up desktop - but its still not signining on and asking for username and password - meaning - giving a prompt
logs indicate username - domain and password variables are set but still not working
Question - do i need to do a sso mapping (i thought that was not necessary)
2 - do i need to setup NTLM2 sso for this ?
thanks
what variables are defined in rdp sso section?
if source variables are session.sso.token.last.username and session.sso.token.last.password, you need to set these variables…
sso credential mapping is a tool to do it but you can also do it with variable assign
Rdp does not use NTLM sso.
are you sure session.logon.last.domain is configured with NT domain name?
Thanks for the reply -
i have added variable assign -
session.logon.last.username = session.logon.last.username
session.sso.token.last.password = expr { “[mcget session.logon.last.password1]” }
session.logon.last.domain = expr {“RVM”}
and i can see in th elogs as well (debug) - that
_resource_remote_desktop./MGM/S01.domain’ set to ‘RVM’
resource_remote_desktop./MGM/S01.password’ set to ‘**********’
resource_remote_desktop./MGM/S01.username’ set to ‘TESTUSEr’
but still - get a logon prompt when i launch RDP
Did you set a ssl profile to the vs?
if yes, don’t use APM default server ssl but serverssl.
i got issues with sso because APM did not trust rdp server CA (not listes in trusted ca defined in this ssl profile)
hi - i am using server ssl
Is the variable session.logon.last.password1 encrypted?
In variable assign for password, set it as secured and use expression
expr { “[mcget -secure session.logon.last.password1]” }
no luck
no luck
