SSO logout process with f5
We are using a salesforce application that uses f5 as SSO IDP. Every time a user logs out it gets the next error messsage from https://hsc-idp-camino.health.unm.edu/saml/idp/profile/post/sls
The requested file was not found on the server. Please contact system administrator!
Question 1: How can we do to change the content of this message?
Question 2: We might like to redirect to another webpage instead of showing this message. How can this be done?
Thanks in advance Jose C. Cabrera Zuniga
Looks like, The Single Logout is missing on your idp.
Did you configure it in your IDP profile on F5 ?
SLO is configured on the IdP but it may not be configured correctly. The configuration that is in place on the IdP… SLO Request URL: blank SLO Response URL: https://hsc-idp-camino.health.unm.edu/saml/idp/profile/post/slr …is able to end the sessions both in the F5 and in SF when the user logs out of SF. However, it also results in the error that you are seeing. The information in the SF Single Sign-On Implementation Guide (Winter '16), “Start, Login, and Logout URL Values” and “Customize SAML Start, Error, Login, and Logout Pages” sections are not clear as to how to configure the Identity Provider Logout URL and the Custom Error URL fields in the SF SAML SSO Settings configuration page Can you please give us more details about how to do this configuration? Thanks
The following is the url of the SLO request : https://hsc-idp-camino.health.unm.edu/saml/idp/profile/post/sls
Are you sure that you are using the same binding method on both SP and IDP : POST or REDIRECT ?
