Here i use Client Auth Using Http Cookie iRule
when CLIENT_ACCEPTED {
set authinsck 0
set forceauth 1
set ckname BIGXAUTH
set ckpass 1xxx5678
set ckvalue [IP::client_addr]
set ckdomain .Acme.com
set asid [AUTH::start pam default_ldap]
if {[HTTP::cookie exists $ckname]} {
HTTP::cookie decrypt $ckname $ckpass 128
if {[HTTP::cookie value $ckname] eq $ckvalue} {
set forceauth 0
HTTP::cookie remove $ckname
if {$forceauth eq 1} {
AUTH::username_credential $asid [HTTP::username]
AUTH::password_credential $asid [HTTP::password]
AUTH::authenticate $asid
HTTP::collect
when HTTP_RESPONSE {
if {$authinsck eq 1} {
HTTP::cookie insert name $ckname value $ckvalue path / domain $ckdomain
HTTP::cookie secure $ckname enable
HTTP::cookie encrypt $ckname $ckpass 128
when AUTH_SUCCESS {
if {$asid eq [AUTH::last_event_session_id]} {
set authinsck 1
HTTP::release
when AUTH_FAILURE {
HTTP::respond 401 “WWW-Authenticate” “Basic realm=\”\“”
when AUTH_WANTCREDENTIAL {
when AUTH_ERROR {
HTTP::respond 401
This Irule use for ldap auth.
I create Acme.com domain
So what changes required for cookie name & password & domain for successfull Auth using HTTP cookie
