SSLv3 detection and redirect using Traffic Policies
I am looking at a way to to redirect any users that are using browsers that only support or allow the use of SSLv3 (i know, i know, nobody should but they still do…)
I could do this under an iRule but the site it will be used on is already heavily using iRules and has a lot of users and traffic coming in and I was looking at doing this via a Traffic Policy.
Problem is that the F5 website isn’t very forthcoming with help on what I should check for under operand of client-ssl and what parameter I should be checking for under protocol to force a redirect to a pool explaining that they should really be using a better browser.
Any help on this would be appreciated.
i think protocol is same as SSL::cipher version.
SSL::cipher
configuration
[root@ve11b:Active:In Sync] config  tmsh list ltm rule qux
ltm rule qux {
    when CLIENTSSL_HANDSHAKE {
  log local0. "\[SSL::cipher version\]: [SSL::cipher version]"
[root@ve11b:Active:In Sync] config  tmsh list ltm policy cpm1
ltm policy cpm1 {
    controls { forwarding }
    requires { tcp http client-ssl }
    rules {
        rule1 {
            actions {
                0 {
                    log
                    write
                    message SSLv3
            conditions {
                0 {
                    client-ssl
                    protocol
                    values { SSLv3 }
            ordinal 1
        rule2 {
            actions {
                0 {
                    log
                    write
                    message TLSv1
            conditions {
                0 {
                    client-ssl
                    protocol
                    values { TLSv1 }
            ordinal 2
    strategy first-match
 /var/log/ltm
[root@ve11b:Active:In Sync] config  tail -f /var/log/ltm
Jun 10 22:44:12 ve11b info tmm1[10343]: Rule /Common/qux : [SSL::cipher version]: SSLv3
Jun 10 22:44:12 ve11b info tmm1[10343]: 016e0004:6: Policy log message [/Common/cpm1/rule1]: SSLv3
Jun 10 22:44:17 ve11b info tmm[10343]: Rule /Common/qux : [SSL::cipher version]: TLSv1
Jun 10 22:44:17 ve11b info tmm[10343]: 016e0004:6: Policy log message [/Common/cpm1/rule2]: TLSv1
