SSL VPN Firepass TCP port Issue
Can anyone help me on this issue? How will you resolve this?
Below is the error message:
WARNING! The local TCP port number used by the App Tunnel adapter for the application you are trying to connect has changed due to the conflicts with another application on your local system, that uses the same port. To continue, do one of these settings:
temporarily shutdown the the conflicting program, and then restart the App Tunnel
reconfigure the App Tunnels client applciation to connect to the alternate port shown
reconfigure the conflicting application to use a different TCP port
Your help is greatly appreciated here.
Thanks,
IrwinBats
You can change the application tunnel to use a different local port. This should resolve the issue.
