newb question. We are currently demo-ing the SSL VPN edge client on a LTM-VE lab with APM. we are ruuning on 11.1 HF2 and i walked through the network setup wizard and i think i have it setup right. I am able to connect to through the client and get an IP address from the scope. but when i do a ipconfig, i dont see a default gateway for the IP in the pool.. is that normal? if not how do i fix that?
If you do a “route print” from the command line, do you see the routes there?
