Please lend me your wisdom. We are providing LTM multi-tenant environment with LTM.
I want to know, ssl transaction per Route-Domain. Is there a way to acquire the SSLTPS value for each root domain with SNMP Get etc?
no i don’t believe so, route domains and / or administrative partitions are just thin virtual borders for some configuration parts and routing. statistics are usually collected box wide. you also can’t use them to protect resources from each other, it is one pool.
