Hi all,
we have HTTPS application using ssl. In Virtual server receiving packets 900 connection but back connection only 300.. my question is why so difference connection between VS and Node.
Hi all,
Hi Vijay,
did you activate the Oneconnect feature in your VS?
For info: When a OneConnect profile is enabled for an HTTP virtual server, and an HTTP client sends multiple requests within a single connection, the BIG-IP system is able to process each HTTP request individually. The BIG-IP system sends the HTTP requests to different destination servers as determined by the load balancing method. Without a OneConnect profile enabled for the virtual server, the BIG-IP system performs load-balancing only once for each TCP connection.
Regards,
