SSL/TLS Ciphers and PFS
Hello devs!
I’m trying to wrap my head around all things crypto and thus I have some questions for you guys:
My understanding is that most TLS1.2 ciphers suites uses Diffie-Hellman or RSA for the key exchange and so, the certificate/key that you configure under the client-ssl profile has nothing to do with the key exchange itself. Correct?
Which key exchange protocol uses the certificate/key under the client-ssl profile to cipher the secret and does not have FS?
I found K16700 that have an iRule that takes notes of sessionids+master-keys. Is it correct to assume that with this iRule, I can capture most modern TLS1.1 and TLS1.2 cipher suites and decrypts client traffic? I ask this because since I first read about PFS I was very worried that I would never be able to capture and see what was going on at L7, but to me, it seems that if you capture session-id+master-key you can pretty much decrypt those PFS ciphers, meaning PFS means that if you don’t capture session-id+master-key you’re in trouble because the client-ssl private-key won’t help.
Thanks!
Hello rafaelbn
The PFS depends of the Key Exchange (Kx) which is part of the cipher suite
openssl ciphers -v
ECDHE-RSA-AES256-GCM-SHA384  TLSv1.2  Kx=ECDH  Au=RSA  Enc=AESGCM(256)  Mac=AEAD
A good explanation of the cipher suite here → https://www.youtube.com/watch?v=ZM3tXhPV8v0
The term ‘ephemeral’ refers to protocols which implements PFS
  • ECDHE - Elliptic-curve Diffie-Hellman Ephemeral
  • DHE - Diffie-Hellman Ephemeral
ECDH, DH, RSA have not PFS.
The TMM uses their own set of cipher suites:
tmm --clientciphers NATIVE
You can custom your clientssl profile to use any specific set of cipher suites.
More info here → myF5
Regarding to decrypting, to decrypt a PFS Key Exchange you should have the random number of the exchange and the private key. In case of RSA, you only need the private key.
KR, Dario.
