Currently we have an iRule that selects the pool based on the URL path. Some pools accept SSL while others do not. In the IF statement (which is in the HTTP_REQUEST event block), if the traffic is forwarded to a pool that doesn’t support SSL we have the command SSL:disable serverside. However, it seems that occasionally SSL is not being disabled correctly. Looking around it seems this may be because we should have SSL being disabled in the SERVER_CONNECTED block. I’ve modified our iRule to disable SSL by default, select the pool in the HTTP_REQUEST block and then re-enable SSL if needed in the SERVER_CONNECTED block. However, it seems that my string comparisons for the pool name in the SERVER_CONNECTED block are not working correctly. Any help on what I’m doing wrong in this iRule is appreciated.
Current iRule:
when CLIENT_ACCEPTED {
SSL::disable serverside
set default_pool [LB::server pool]
HTTP::header insert "X-Forwarded-Proto" "https"
if { [HTTP::uri] starts_with "/foo" } {
pool pool_foo_https
elseif { [HTTP::path] starts_with "/bar" } {
pool pool_bar_http
else {
pool $default_pool
when SERVER_CONNECTED {
if { ([string tolower [LB::server pool]] matches "pool_foo_https") } {
SSL::enable serverside
else {
You should absolutely be able to use SSL::disable serverside in the HTTP_REQUEST event. You may alternatively want to adjust how you’re filtering on the URIs, and/or investigate if these URIs are consistent.
if { [string tolower [HTTP::uri]] starts_with "/foo" } {
pool pool_foo_https
} elseif { [string tolower [HTTP::uri]] starts_with "/bar" } {
pool pool_bar_http
pool $default_pool
This thread is 3 years old but the original question had “SSL::enable serverside” in BOTH if and else conditions and that’s why the if statement on the pool is not working correctly.
