ssl re-direct
Hi
Ive looked through a few irule examples but cant find exactly what I need…basically I want to do a https redirect on a VS so..
user goes to https://site.name.com/ but I want it to re-direct of to https://site.name.com/abc - is this easily achieved?
    if { [HTTP::uri] equals "/" } {
        HTTP::redirect "https://[HTTP::host]/abc"
You must of course also have a client SSL profile applied to the VIP to be able to process the layer 7 HTTP traffic.
Thanks for that , ill give it a go! I have a client ssl profile setup which contains the cert etc. do I need to set anything else in this profile?
works perfectly!
thanks you!
