First of all let me tell you how the setup is. I’ve got a public interface and an inside interface. Servers on the inside are not in the same vlan as de F5. Routes are defined on F5 to reach those servers.
The problem that I’m facing is to publish two differend SSL sites with differend backend servers/pools and these need to be published on the same virtual Server address. When I try to create this, I get the following error :
> 01070333:3: Virtual Server /Common/VS_xxx illegally shares destination address, source address, and service port with Virtual Server /Common/VS_yyy.
I found follwoingprocedure on F5 website :
404 Page not found | BIG-IP Documentation
Only thing is that I don’t have got 2 differend VLANS on the inside, I use routes. So this procedure does not seems to be working for me.
Anybody already countered the same issue? Any help is much appreciated.
Kind regards
ps : for the moment F5 is will only be used as a reverse proxy.
