I have a SSL parent profile ( client ) using a set of custom profiles. I’ve then configured 2 * SSL client side SSL profiles using this parent profile. I’ve then used the two SSL profiles on two separate VIPs.
When I run a SSL Server test using SSL Server Test (Powered by Qualys SSL Labs) I’m getting a rating of B ( i.e good ) on one of the VIPs but a very poor rating of F on other other site.
The problem seems to be related to one of the SSL client side cipher being used - TLS_DH_anon_WITH_AES_256_CBC_SHA (0x3a) INSECURE
I trying to understand why this is being used, it’s not in my Cipher list & even if it why is one profile fine but the other is not.
Hope this makes sense → overall, the cipher list is listed within the parent profile which is being used in two SSL Client side profiles which seem to be behaving differently.
