SSL Orchestrator VE deploy fails
Hi Devcentral community,
I trying to deploy SSL Orchestrator in inline mode ( layer 2 / transparent) but the deployment fails.
I tried to use BIG-IP 13.0 VE HF2 and SSL Orchestrator version 2.3.4
I also tried to follow the troubleshooting steps defined in the guide but without any success:
Do you have any suggestions?
I am not able to delete the “SSL Orchestrator” configuration and the error detail is “Application Undeployed”
Thanks.
M
Fixed. Using default ssl orchestrator package(do not upload any updated SSL orchestrator package )
Can you clarify how you got it to work.. When you say ‘default’ package, is this part of 13.0 VE HF2? And what version of the Orchestrator is it that you have deployed?
What do you have in production? Thanks!
