I want to offload inbound ssl and re-write the cleartext tcp destination field to a new tcp destination port e.g. tcp443 to tcp80. I’m using an F5 LTM product. Does anyone have a sample config?
is it normal ssl offload configuration?
e.g.
[root@ve11a:Active:Changes Pending] config tmsh list ltm virtual bar
ltm virtual bar {
destination 172.28.20.111:443
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
clientssl {
context clientside
tcp { }
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 23
[root@ve11a:Active:Changes Pending] config tmsh list ltm pool foo
ltm pool foo {
members {
200.200.200.101:80 {
address 200.200.200.101
[root@ve11a:Active:Changes Pending] config curl -Ik https://172.28.20.111
HTTP/1.1 200 OK
Date: Thu, 29 Aug 2013 04:28:31 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Thu, 23 May 2013 00:28:46 GMT
ETag: "4185a8-59-c3efab80"
Accept-Ranges: bytes
Content-Length: 89
Content-Type: text/html; charset=UTF-8
e.g.
ltm virtual bar {
ip-protocol tcp
pool foo
profiles {
clientssl {
context clientside
tcp { }
source 0.0.0.0/0
type automap
vs-index 23
ltm pool foo {
members {
HTTP/1.1 200 OK
Content-Length: 89
ok lets assume on inbound traffic i want to use a gigamon device to send a copy of the ssl traffic to an ltm for ssl offload then send the decrypted cleartext to another inspection device to inspect the cleartext http as port 80 per config above, then can i reverse that process and inspect the outbound server traffic by using gigamon to send a copy of the encrypted server return traffic to the ltm to be decrypted and forwarded to the inspection device to inspect the server return traffic?
can you do something like this instead?
Divert Unencrypted Traffic through an IPS with Local Traffic Manager by Jason Rahm
