SSL offload on non-standard port
Hi
We have application which run on port 8945.
Can we perform ssl offload on this port?
I try to create virtual server port 8945 with SSL client profile but when user connect (or server return http 30x) with http://app.com:8945 … Application is fail due to we have ssl client profile configured.
I understand if server use standard port 80, we can config two virtual server (80,443) then perform offload on vs port 443 and redirect on vs port 80. but in this case we can’t create two virtual server with the same port 8945.
Thank you
u have a ssl profile and you are trying to access VIA Http use https
if you confgure ssl offload you can not user plain text any more until an iRule is applied to disable ssl
