SSL memory consumption
Hi all,
I am currently designing a new area of our Data Center, in which both layer-7 decisions and SSL off-loading will take place. I am using two 6800 platforms in a cluster and plan on balancing the different farms across the two boxes. My question is, since I going to have quite a bit of SSL traffic I was wondering about the the design. I have been searching the literature for the platform’s memory consumption and distribution with no luck - can anyone put me on the right direction?
Gil
I haven’t found any myself. However, there is a link that might hint as to where to look
thank you. Is there a way to measure memory usage per SSL tps
