SSL Intermediate Chain Certificate Installation in LTM
Hello All, I’m working on a task for an SSL Intermediate Chain Certificate Installation in LTM.
Can you please guide me the steps to add SSL Intermediate Chain Certificate?
Regards, Thiyagu
Please see this askf5 solution sol13302
Thanks Nathan for your reply. Could you please help me to know how to test the intermediate chain certificate is working properly?
What are the testing we can do from the LTM standpoint and confirm that things are working?
What are the testing we can do from the client perspective and confirm the installed certificate is working as expected?
Your quick help would be appreciable.
Regards, Thiyagu
Jason Rahm did a series on SSL. This one is all about chain certs. This should help test: https://devcentral.f5.com/s/articles/ssl-profiles-part-3-certificate-chain-implementation
Thanks Nathan. I have one more question related to this. If the SSL certificates in use today signed by a Certificate Authority (CA) using the SHA-1 algorithm then using of SHA2 intermediate certificate will work for the successful SSL handshake between client and the server?
Or
Do we need a new SSL certificate with SHA 2 algorithm and an intermediate chain certificate in LTM to make the successful SSL handshake between client and the server?
Regards, Thiyagu
Or
Regards, Thiyagu
It depends on the client’s browser. For example Google Chrome requires the whole chain except the CA to have SHA2 Certificates - so it’ll reject yours. Internet Explorer OTOH will probably accept it.
