Hi All, fairly new to using an iApp - so here is my question.
We need to be using the SSL_intercept_SVC_chain iApp to mitigate the scenario where TLS 1.0 is no longer supported in the big wide world. Basically we have a number of old apps that will only use TLS 1.0 and since this is now being deprecated we plan to use the F5 to handle the client to F5 as TLS 1.0, but then forwards onto external sites as TLS1.2 or 1.3.
I have downloaded the iApp, and have worked out all the settings I need to use to make the Application Service - however what I don’t get is how to join together the AS and a virtual server.
We plan to use an internal DNS entry for selected external sites so that the traffic is forced to the F5 and passed to the internet, and away from our proxies thereby using the F5 to do the TLS re-negotiation/upgrade.
We have a two LTMs running in HA so its not a case of passing it from one F5 to another F5 via a decrypt zone.
Once I have run the iApp - what do I need to do to use it.
