SSL Intercept and clearing certificates
In case of SSL Intercept LTM is creating on the fly certificates on the client side to decrypt traffic.
I can see in VS stats in SSL Forward Proxy for client profile position:
Cached certificates: X
Is there a way to see list of this cached certs or clear this cached certs?
Is there any setting responsible for how log those certs are cached? I assume that not the ones for Cache Size and Cache Timeout (in clientssl profile as well)?
Piotr
cached-certs
Displays and deletes SSL Forward Proxy cached certificates on the BIG-IP(r) system.
Syntax
Use the cached-certs component within the ltm.clientssl-proxy module to manage connections using the
following syntax.
Display
show cached-certs
virtual [name]
clientssl-profile [name]
Delete
delete cached-certs
virtual [name]
Description
You can use the cached-certs component to display or delete SSL Forward Proxy cached certificates based
on a specified clientssl profile.
Options
• virtual
Specifies the name of the virtual server that you want to display or delete cached certificates from.
• clientssl-profile
Specifies the name of the clientssl profile that belongs to the virtual selected.
See Also
delete, show, tmsh
Thanks a lot Piotr
