SSL Inspection Bypass
Im in the process of setting up SSL inspection on browsing traffic for a client. I have been using F5’s deployment guide (https://www.f5.com/pdf/deployment-guides/ssl-intercept-dg.pdf) to set this up and for the most part is working.
However when I apply the specified iRule from the deployment guide to bypass certain URL categories for inspection, HTTPS browsing fails baring those which are being bypassed.
Example’s… When I hit https://www.hsbc.co.uk with the below iRule applied to my Wildcard VS, I am presented with HSBC’s cert as you would expect. But going to https://www.reddit.com bombs out completely. HTTP browsing is fine. If I removed the iRule, inspection works perfectly to every HTTPS site but obviously I dont want to be inspecting everything. Also without the iRule HTTP browsing bombs.
Any ideas?
when RULE_INIT {
 set static::airgap_ssl_bypass_categories {
  you can add or remove Categories. See Access Policy - Secure Web Gateway - URL Categories for a list of options
    /Common/Financial_Data_and_Services
    /Common/Health
    /Common/Facebook_Chat
when CLIENT_ACCEPTED {
    HTTP::disable
    SSL::disable clientside
    SSL::disable serverside
    TCP::collect
when CLIENT_DATA {
    binary scan [TCP::payload] c type
    if { ( $type == 23 ) or ( $type == 20 ) } {
        SSL::enable clientside
        SSL::enable serverside
    } elseif { $type == 22 } {
        HTTP::enable
    TCP::release
when CLIENTSSL_CLIENTHELLO {
    set sni_exists [SSL::extensions exists -type 0]
    if { $sni_exists } {
        binary scan [SSL::extensions -type 0] S1S1S1cS1a* ssl_ext_type ssl_ext_len ssl_ext_sn_list_len ssl_ext_sn_type ssl_ext_sn_len ssl_ext_sn
when SERVERSSL_HANDSHAKE {
    if { not $sni_exists } {
        set ssl_bypass_mitm 0
        set subject [X509::subject [SSL::cert 0]]
        regexp {CN=(.*?),} $subject fullcn subcn
        if { [info exists subcn] } {
            set this_uri "http://$subcn/"
            set reply [getfield [CATEGORY::lookup $this_uri] " " 1]
            set decision [lsearch -exact $static::airgap_ssl_bypass_categories $reply]
            if {[lsearch -exact $static::airgap_ssl_bypass_categories $reply] >= 0}{
                set ssl_bypass_mitm 1
            regexp {CN=(.*?)$} $subject fullcn subcn
when CLIENTSSL_SERVERHELLO_SEND {
    if { not [info exists ssl_bypass_mitm] && [info exists ssl_ext_sn] } {
        set this_uri "http://$ssl_ext_sn/"
    if { [info exists ssl_bypass_mitm] } {
        if { $ssl_bypass_mitm } {
            SSL::forward_proxy policy bypass
            catch { HTTP::disable }
            SSL::forward_proxy policy intercept
when SERVER_CONNECTED {
    if { [info exists ssl_ext_sn] } {
        HTTP::header insert X-Proxy-HTTPS "[TCP::local_port]:${ssl_ext_sn}"
        HTTP::header insert X-Proxy-HTTPS "[TCP::local_port]:0"
    LB::detach
    pool Internet_Gateways
Hello,
Why not just set up an SSL forward proxy configuration and apply a specific SSL profile for that :
You can also define a bypass list within the SSL profile directly
Hello,
That method would require that I manually input every site/hostname that I would like to bypass. The intention here is to use URL DB Categories from the SWG to determine which sites should be bypassed (see the F5 documentation I linked). And as mentioned in my post, the bypassing isnt the issue here. The fact is that the above iRule which is supplied by F5 verbatim as part of their deployment guide is for some reason bombing out non-bypassed HTTPS connections.
Are you sure that a “non-bypassed” connection hit the following command within the irule : SSL::forward_proxy policy intercept Did you add some logs in the irule to check the path used for those failing connections ?
I did not add anything to the iRule. It’s taken verbatim from F5’s documentation baring changes to pool information. How would I log that to be sure?
you can add the following command where you need it : log local0. “my custom log information” I suggest to put a log after each if or else condition
Sorry didnt see this response. Will try the logging today and see if its hitting the SSL forward proxy policy
