SSL handshake Failure
one of my VIP were using ssl profiles, I updated ciphers in my ssl profile not to use RC4 and then changes were reverted to default. but after that i am unable to open that site in browser. After checking SSL dump i can see ssl handshake failure. i.e New TCP connection 4: 172.16.2.83(55847) ↔ 199.96.220.18(6443) 4 1 1398154000.3027 (0.3390) C>SV3.1(114) Handshake ClientHello Version 3.1 random[32]= 53 56 23 77 70 87 2f d4 74 d1 e7 b0 ac 3d 16 ab 18 6d 3e 14 e6 1b bb 28 c1 87 0c 7d 33 0f 9c 0d cipher suites TLS_RSA_WITH_AES_128_CBC_SHA TLS_RSA_WITH_AES_256_CBC_SHA TLS_RSA_WITH_3DES_EDE_CBC_SHA Unknown value 0xc013 Unknown value 0xc014 Unknown value 0xc009 Unknown value 0xc00a TLS_DHE_DSS_WITH_AES_128_CBC_SHA TLS_DHE_DSS_WITH_AES_256_CBC_SHA TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA compression methods NULL 4 2 1398154000.3027 (0.0000) S>CV3.1(2) Alert level fatal value handshake_failure 4 1398154000.3028 (0.0000) S>C TCP FIN 4 1398154000.6416 (0.3388) C>S TCP FIN
is clienthello cipher included in clientssl profile?
sol13156: SSL ciphers used in the default SSL profiles (11.x)
tmsh list ltm profile client-ssl star.mysite.com all-properties ltm profile client-ssl star.mysite.com {
alert-timeout 60
allow-non-ssl disabled
app-service none
authenticate once
authenticate-depth 9
ca-file ca-bundle.crt
cache-size 20000
cache-timeout 3600
cert mysite.com_2011.crt
cert-extension-includes none
cert-lifespan 30
chain geotrust_inter_2011.crt
ciphers RC4:!SSLv2:!EXPORT40:!EXP:!LOW
client-cert-ca none
crl-file none
defaults-from clientssl
description none
handshake-timeout 60
key mysite.com_2011.key
mod-ssl-methods disabled
mode enabled
options { dont-insert-empty-fragments }
partition Common
passphrase none
peer-cert-mode ignore
proxy-ca-cert none
proxy-ca-key none
proxy-ca-passphrase none
proxy-ssl disabled
renegotiate-max-record-delay 10
renegotiate-period indefinite
renegotiate-size indefinite
renegotiation enabled
secure-renegotiation require
server-name none
session-ticket disabled
sni-default false
sni-require false
ssl-forward-proxy disabled
strict-resume disabled
unclean-shutdown enabled
which was clientssl profile used when having an issue? was it star.mysite.com or clientssl?
star.mysite.com.
star.mysite.com.
is it inherited from clientssl profile? is ciphers set to RC4:!SSLv2:!EXPORT40:!EXP:!LOW?
alert-timeout 60
app-service none
authenticate once
cache-size 20000
cache-timeout 3600
cert-lifespan 30
client-cert-ca none
crl-file none
description none
mode enabled
partition Common
passphrase none
proxy-ca-cert none
proxy-ca-key none
proxy-ssl disabled
server-name none
sni-default false
sni-require false
yes it is.
so, doesn’t it work as expected (connection is terminated) since clienthello cipher suite does not contain rc4?
No its not working. Whenever it try to connect it. Browser do not load any thing. and from tcpdump/ssldump. I only get this information.
This is the lates one
New TCP connection 38: 172.16.2.83(59404) ↔ 199.96.220.18(6443)
38 1 1398157934.8606 (0.3549) C>SV3.1(123) Handshake
ClientHello
    Version 3.1
    random[32]=
      53 56 32 d6 73 79 f1 55 ce d9 0c ae a5 fe b1 f3
      fb d3 0b 3b 0c f0 32 8b 7d 63 c0 43 20 cf de 1f
    cipher suites
    compression methods
              NULL
38 2 1398157934.8607 (0.0001) S>CV3.1(2) Alert level fatal value handshake_failure 38 1398157934.8607 (0.0000) S>C TCP FIN
you are using star.mysite.com clientssl profile, aren’t you?
RC4:!SSLv2:!EXPORT40:!EXP:!LOW is set as ciphers in star.mysite.com clientssl profile (according to tmsh list ltm profile client-ssl star.mysite.com all-properties), isn’t it?
if yes, i understand not-working is expected behavior because there is no rc4 in clienthello cipher suite.
do i misunderstand something?
What would be the rectification for it. ?
you can set ciphers in star.mysite.com clientssl profile to DEFAULT or ALL, can’t you?
Now CIPHER Set is changed to
TLS_RSA_WITH_AES_256_CBC_SHA (0x35) 256
TLS_RSA_WITH_3DES_EDE_CBC_SHA (0xa) 112
TLS_RSA_WITH_AES_256_CBC_SHA256 (0x3d)  256
I am unable to understand even RC4 was included, why it was not working. Can you guide.
You specified RC4 in your client SSL cipher string and, it would seem, never changed that.
This cipher list represents the server’s cipher capability, and since the client wasn’t presenting any RC4 ciphers, the session was terminated. Changing the cipher string back to “DEFAULT” would have solved that problem.
