Both our production and non-production service desk applications use SSO.
User connects to application VIP, which redirects users to the SSO VIP on 443.
The F5 configuration for these two environments are identical:
SSL bridging with default Client SSL profile as parent. No customizations except for the certificate/key/bundle.
However in the non-prod environment, the SSL handshake cannot complete. tcpdump shows a fatal error, certificate unknown, even though this is the same cert/key on the SSO server.
Okay, so to be clear, “SSL Bridging” generally defines where the F5 both decrypts and re-encrypts the traffic to the server, which requires both client and server SSL profiles. If I can assume that there is NO client certificate auth going on, on either side, then the “certificate unknown” error is going to come from the client after consuming the server’s certificate.
Browsers aren’t usually that strict about bad server certificates. Worst case you’ll get a certificate warning and click-to-continue.
So then I’d ask,
Does the app server require HTTPS?
Do you have a server SSL profile also applied?
And if yes to the above, which server SSL profile are you using?
Here is what I see when the dev application owner points the redirect at my lab virtual server, which has the clientssl profile that is identical to the known-good production setup.
1 1 0.0012 (0.0012) C>SV3.3(161) Handshake
ClientHello
Version 3.3
random[32]=
5b 89 7a b6 35 98 e1 be de 21 a4 60 62 ef 00 9e
93 95 37 7c 4f db dc 02 c1 c4 0d ec 53 fe fb 8e
cipher suites
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
TLS_RSA_WITH_AES_128_CBC_SHA256
TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256
TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
TLS_DHE_DSS_WITH_AES_128_CBC_SHA256
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
TLS_RSA_WITH_AES_128_GCM_SHA256
TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256
TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256
TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
TLS_DHE_DSS_WITH_AES_128_GCM_SHA256
TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA
TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA
TLS_RSA_WITH_3DES_EDE_CBC_SHA
TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA
TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA
TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA
TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA
TLS_EMPTY_RENEGOTIATION_INFO_SCSV
compression methods
NULL
ERROR: Length mismatch
The second one is truncated with the “Length mismatch” error, but can I assume the second one works?
In any case, what you’re seeing here is the server side rejecting the client right after the client hello message. The only thing that generally happens in this message is the client sending a preferred TLS protocol, a list of supported ciphers, and any number of TLS extensions (ex. SNI, EC points, etc.).
There is something in the client’s client hello message that the server does not like, and is therefore closing the connection. At this stage it can only be a disagreement in one of these things: TLS protocol, ciphers, TLS extensions. I don’t actually see the TLS extensions in the capture though.
So to clarify, who is the client and who is the server in this capture?
I asked the customer if he can change the ciphers on the application servers, since I’m not allowed to make a change to my F5 configuration. Here is the config of the parent clientssl profile showing the defined ciphers, which I believe don’t match up with any ciphers in the client hello
When I compare the ciphers allowed in the clientssl profile and what was sent in the Client Hello packet, it looks to me like there are no ciphers that both sides agree upon.
Alright, so we got a new SSL certificate and my theory does not appear to be correct. The clientssl parent profile has been changed to the clientssl-insecure-compatible
Zuke, you may have answered this but I didn’t see it. Can I assume this is a non-browser client? A browser would usually issue a certificate warning to the user and allow the user to bypass the error. A browser client would likely never send this:
22 6 0.0042 (0.0006) C>SV3.3(2) Alert
level fatal
value certificate_unknown
which basically implies that the client (C>S) does not trust the itsdtest.example.com server certificate.
